1.9 ASZ to 2.0 BKD.
jos_br
Netherlands
Audi TT>TDI
The first ASZ/BKD engine is running well with bigger injectors and a hybride FIN-turbo.This week it will be remapped.
Jos.
m1ketdi
Leam
Leon BKD
Jos.
Is this using the ASV ecu? What mapping changes are happening to run these injectors ? Or is it just wiring that needs to change.
hatemi
Finland
Audi A6 4F 3.0TDI
AFAIK it should be just a matter of duration and SOI maps to get it running good enough.
jos_br
Netherlands
Audi TT>TDI
This is the result (270HP/497nm)for now, without any smoke. We have decreased the torque because of the dual massflywheel, maybe try a single one.
Engine is running very smooth and feels powerfull.
Jos.
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
Tom.
Doncaster UK
SEAT Ibiza PD130
Its the standard ASZ oil filter with an aftermarket sandwich plate for a remote cooler by the looks of it.
JFettig
Blaine, MN
B5 Passat, 2010 Jetta
Nope, the ASZ oil filter setup is the same as the ALH or BEW
Here is my ASZ(much cleaner now)
JFettig
Blaine, MN
right, I explored a similar oil filter housing from a BKD and was told it wouldn't work on my ASZ block. The one pictured above is similar to the BKD if not the same. I sent jos_br a PM regarding part numbers.
jos_br
Netherlands
Audi TT>TDI
There are two types off ASZ engines (european), the latest one has the same oil filter housing as the BKD.
Jos.
X@V
Sherbrooke, Qc, Canada
B7 A4 V6 2.5TDI, MK2 frankentdi 2.0 16V TDI PD
There were some ASZ using EDC16U31 ECU, are these the late ASZ? (in the Seat / Skoda)
I'm curious!
v8 coupe
bloomington, mn
09 rabbit 2.5L Gas
I'm interested in knowing what all is needed is it just tunning or are there physical changes needed to change a Pd130 style system over to run a BKD?
jos_br
Netherlands
Audi TT>TDI
We have build an AJM (1,9tdi/115hp) block, a (non ported) BKD head, some "stuff" :rolleyes: from Rayn (exhuastmanifold) and a FIN-turbo (mod. 2260) with he next results,
This was possible, but we want to try to hold the gearbox longer.....,
Engine runs a Audi A4 edc15 computer.
Jos.
