1.9 ASZ to 2.0 BKD.
Tom.
Doncaster UK
SEAT Ibiza PD130
As above, I'm looking to change from a 1.9 PD130 engine, to the 2.0 PD140 engine.
To cut a long story short, trackday, white/blue smoke, down to 3 pistons.
What does it take to convert it to the newer 16v engine? I've spoken to Ryanp and he says my current ecu won't get on with the engine, and that mk5 platform ecu, won't work with the rest of the car. Just wondering if anyone can shed any more light on the situation, and what it will actually take?
The car is an 04 SEAT Ibiza PD130 with the ASZ lump.
Thanks in advance,
Tom.
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
Look at the FSI conversions into Mk4's, they make the Mk5 engine run on a simple Mk4 loom, Crank trigger is the main hurdle!
turbo johan
Bore asz block and put bkd pistons in it.
run bkd head and asz ecu.
Easiest i think.
johan
Lofty86
Chippenham, UK
Mk5 VW Golf 2.0 16v PD140
Really, swapping heads will work? (with correct bore and pistons).
Id be more interested in this for sure..
Mate had a 16v head on his classic Mini for a while, from a bmw bike. Went like stink.
...Sorry, off topic.
Do all the water ways and oil ways align ok? And how do you go about setting up cam positions when putting the head on.. Suppose you just treat it like a normal 16v?
Any sensors on the 16v head that need mod'ing or any on the 8v block?
TIA Dave.
Lofty86
Chippenham, UK
Oh Oh, my 'head supplyer has sorced me one already for next to nothing, but dont want to get it if its going to cost more than the big valve 8v im part way through doing.
What hp/torque are these heads good for?
Hoping im going to be selling my head and D24 inlet to fund this if ££/hp works out well.
D
Tom.
Doncaster UK
SEAT Ibiza PD130
Thanks for the replies lads.
Johan. Have you seen 16v head on a bored out ASZ done before? Deffinately a route im interested in!
3L3M3NT
Sturgeon Bay, WI
04 Jetta GLS TDI, 04 RTDI
I was kind of wondering about this upgrade for my BEW and dropping in a BKD. I'm assuming there would be similar issues.............
borachris
UK-Billingham
Bora ASZ 130PD, Corrado 150PD in production
Easiest i think.
johan
The ASZ ecu can control the BKD injectors?
I thought the BKD used the PPD injectors and could only be controlled by the siemens ECU?
I've only ever seen a 140 passat in bits up close and it definitely had the siemens stuff, or is it another case of some do and some don't?
ryanp
140 BKD's have Bosch injection. a few people have started making them work with Mk4 ECU/Wiring but i've never seen it finished!
borachris
UK-Billingham
Interesting!
I'll have to look into that a bit more, might be worthwhile for the mk2 instead of blowing big bucks on a ported 8v head
Lofty86
Chippenham, UK
... instead of blowing big bucks on a ported 8v head
Thats my thinking. (although I have an 8v head and its part ported).
But if the BKD head with the bosch version injectors will bolt onto my longitudinal AVF block with only a cambelt change , a change of pistons (which im going to do when rebore to 2.0) and a pair off diy manifolds (which Im going to be making for the 8v anyway too). Then I want one!!
I have got that right haven't I??
Which BKD head has the bosch injectors, or can they be changed anyway?
Someone said the BKD's have leaky heads?? True?
Sorry for the hijack, It just sounds like it would be a great mod to go with my rebore, 2066 etc.
Dave
Edit: Also, is it the BKD head thats the only 16v that will fit? D
Carl2k7
Middlesbrough
VW Bora 1.9TDI Audi A4 2.0TDI Sline BMW 530D
TIA Dave.
the KN1100 head from the BMW takes a fair bit of modding to get it to fit on the 1.3 mini :p
Lofty86
Chippenham, UK
Tell me about it!! Blocking water ways etc. Was fun though. And running a belt cam rather than a chain made it soooo much nicer to listen too.
turbo johan
As far as i can see it will work.
I'll build one in a while, i'll let you know when i have problems.
Johan
Lofty86
Chippenham, UK
Back to the top im afraid...
So, BKD head is planned for my AVF. Just got to pick my new (2nd hand) block up for a rebore.
I am right in saying you'd just use the BKD cam belt kit?? or custom job?
Cant wait, but money, as always, is a limiting factor.
Dave
sid_bora_tdi
kendal
bora
well if you want to drop a whole lump in why not get a car and swap everything over like people do for mk2 pd conversions , just take the whole cars loom and make it fit it does help if you are good with electrics though !
Lofty86
Chippenham, UK
I thought that sid, but my electrical skills arnt much, and if i keep the same type of lump then the loom doesnt need touching, just stick it in and get it on a dyno for a tune basicly.
Also, my AVF ecu wouldnt controll the other engine from my understanding, and i really dont want to be making up looms and swapping ecu's. Its expencive enough as is! Ha.
Scufi
United Kingdom
2.0TDi 170
OK. This is the reason I`ve made an account.
I was interested in swapping heads for some time now.
The first problem you will have will be the water and oil channels which are quite different between the two.
You will need to adapt the timing chain accordingly with new tensioners.
There is a new tandem pump on it which has the fuel and vacuum pump.
Depending on the model year, the 2.0 PD can be found with vers 1.2 solenoid injectors or 1.1 piezo injectors (which fail like challenger rockets).
Lofty86
Chippenham, UK
Nice info Scufi.
Iv been there done that when it comes to blocking and re-drilling water ways etc, but dont fancy it on a TDi tbh.
Shame it wasnt a bit easyer, but nevermind. Iv got my big 8v project head to fall back on. And manifold etc.
Dave.
jos_br
Netherlands
Audi TT>TDI
I have used the ASZ from an Ibiza because the oilhousing is the same as the BKD (lower than your AVF engine). I have also changed the wiring, poulie from the timingbelt and the alluminum support because the hydraulic steeringpomp and the extra poulie for the timingbelt.
Jos.
Lofty86
Chippenham, UK
So Jos, you just bolted the head on the ASZ block and it fitted ok? Then used the BKD belt and pullys ?? All OEM parts by the look of it?
What was the wiring you had to do?
Dave
Lofty86
Chippenham, UK
Also, will the ASZ block mate up to my 'box, because if its easyer to build then i would just get a ASZ block instead of the AVF.
Dave
Scufi
United Kingdom
2.0TDi 170
Nice info. The power steering pump gets in the way of .. ?
How did you managed with the new vacuum/fuel pump ?
The engine is up an running or just proof of concept ?
jos_br
Netherlands
Audi TT>TDI
You have to make a new wiring for injectors and glowplugs. The car (golf V)which use the BKD has no powersteering pump.
Jos.
Scufi
United Kingdom
2.0TDi 170
Yes, you are correct about BKD power steering. I want to know if the hydraulic pump found on 1.9 must be removed or can be kept after fitting the 2.0 head and belts.
