Yikes, been a minute. Figure I owe whoever reads this an update (its been almost a year since my last post).
A lot has happened and I'll sum things up. I got a lot of stuff working.
Rear power window motors torn down, clean, lubed up and front window regulators just needed some lube. Now all 4 power windows work great. Power locks werent working right. Car needed a new vacuum pump and a few pin hole leaks in hardlines under the carpet fixed. Power locks (and trunk) work as they should now.
Installed H1/H4 quads, which should be a nice upgrade from the sealed beams.
Installed front seats from an 84 Audi 4000 LE (these had nice sport seats)
Added some good rebuilt calipers up front with new pads and rotors. Rear drums and wheel cylinders looked amazing so I left them alone. Installed new rear wheel bearings at least. Fresh brake fluid and bleed all around.
Main radiator recored (which I wanted ALL summer for), and I actually found a NOS secondary radiator on ebay.
Got some new injectors installed
New starter
Engine bay pretty much all put back together. After some fiddling with bleeding the injectors the car actually ran, which I was happy to see, hear, and smell. This was many months ago though. I got it running before sending the main radiator out for fixing. Car idled great and I got it up to temp. No drama or issues there. I had not driven it yet though because at that time the brakes werent the best.
So where are we?
I've gotten more parts in, mainly for a suspension refresh, which will happen when I know the car drives and stops properly.
Before I knew there was an issue with the brakes I got the car running and wanted to see if it would move. It moved but the brake pedal was really hard. Add to that the clutch pedal engagement was SUPER high, which actually made the car undrivable. Car stalled many times on my street before opting to push it back up the driveway and into the garage.
Having owned only another cable clutch VAG car and never having to mess with it, its all new for me. Looking at the Bentley I notice the release lever needs to be a certain distance from the bracket where the cable is held. I paid no attention to this but also didnt touch it. I assume this is my issue because no matter how I adjust the cable there is basically zero free play at the pedal. I'll work on getting the cable off and adjusting the lever.
Other issue is the brakes. I pulled the vac hose off the brake booster and really didnt feel much suction there. The pump on this car is the smaller, more round one with only 1 vac port on the top. No idea if its the same one that came on the car originally, but based on the original hose I took off, it looks like it. I took the vac pump out and figured there may be an issue here. Mistakes were made when I was trying to get the hose off of the pump. I ended up snapping the plastic piece on top off. That was bad news, but I found replacement tops with seals and such. After weeks it finally came in the mail today. To continue the punishment the top plate is slightly a different shape and the holes dont all line up, so I just extended them so it "worked". At this point I didnt put any new seals in and just tossed the pump in. Not a lot of vacuum at all, so my next move is to replace the 3 seals and see where that gets me. If not guess I'm looking at a new pump? I did try installing one of the larger ones, but it wont really fit right right turbo feed line there and thats a pain to move.
OH, one last thing for now. I went through a few months to even title this thing. Since Georgia doesnt require a title for anything older than 1985 that made things more challenging for me in Indiana. I ended up having to get a court order to acquire a title. Got all that done and registered the car with a period correct 1981 plate. Whats interesting is I do have the original New Jersey title from 1983 in my hands as well. Neat relic.
I'm dying to drive this thing. I'm REALLY hoping I dont have a bad brake booster because those seem tough to find. If anyone has BTDT on this, I'm all ears. Could be a bad master? Not sure.
Some random photos over the months for those that have been kind enough to read this.
The belly pan isnt pictured but I pulled it out from under the car for cleaning. I found 2 pieces of the original block on top. No idea how they survived me moving stuff around.
