ninedee_golf_tdi
Nuts, he made this less than 60 miles from my house and I never knew about it
Although an improvement, that's not much more than the lupo's 84mpg...nicklockard said:I predict real world mpg's of 88-96 depending on driving cycle and style.
Agreed. The 3 cylinder PD engine used in this project is about 2X too powerful and won't operate in its best BSFC range much of the time.Scott_DeWitt said:Although an improvement, that's not much more than the lupo's 84mpg...
http://www.usatoday.com/money/consumer/autos/mareview/mauto497.htm
The ECU in the car is actually for a 1.4L, but it has 1.2L map info.Scott_DeWitt said:Jeff,
have you thought of using the ECM from the 1.2 A2? I don't think the A2 doesn't have that funky auto-manual transmission the Lupo has.....
Mike,vwmikel said:Jake, what is the MAF problem that you're having now? That ECU pretty much has the stock 1.2L maps in it but I'm sure there is room for improvement.
Perhaps we could meet up sometime and try to get some of these issues ironed out. Are you using the cruise control with your setup? If Mark wants to contact me about it, that's fine. I basically just set it up to run like the 1.2L to get things off the ground, but there is definitely more work to be done and I'm sure some improvements to be made.jpstaub said:Mike,
I'll pull the code again tomorrow to relay exactly what the computer is saying. Based on my recollection, the computer isn't happy about the MAF value.
I'm also having a bit of difficulty with the brake pedal position sensor (F and F47). The ECU isn't happy with F. I can bring up an advanced measuring block with F, F47, and F36 which is the clutch pedal position sensor (1/1/0 without brake pedal pressed). F47 and F36 move with brake pedal actuation (1/0 to 0/1 with pedal actuation). I get nothing out of F (constant 1) and a trouble code stating that the value of F is incorrect. Is it possible to tell what positions F, F47, and F36 should hold in the ECU 121 pin connector from the ECU program? I think we've got the wiring right (based on the wiring diagram anyway) and the brake switch is obviously working based on observation. The engine seems to respond fully to the throttle pedal (1.2L SSP suggests that a bad brake pedal switch will limit engine power). Perhaps the advanced measuring block is incorrect (I'm using VAG-COM)?
The MAP value also falls outside the given range of values shown for the sensor by VAG-COM. Is this a result of overlaying 1.2L maps onto a 1.4L computer so that VAG-COM displays a normal range of values based on the 1.4L engine which may not match typical 1.2L values? Lots of of small details I've been thinking about. We're way off the beaten path so it's learn as you go.
Mark Malone contacted me about dialing in the ECU program (http://www.topgear.com/us/features/more/we-build-a-70-mpg-car/). I told him what we did to make the car run. He's expressed interest in working with you to see if improvements could be made and how they might be implemented given our base program.
Best wishes,
Jake
I follow what you're saying except for brake switch F. Based on the wiring diagram I have it appears that when the brakes are off F is open (0V) and when the brakes are on F is closed (12V). I'm having trouble seeing a way to pull F to ground when the switch is open then provide 12V when the switch is closed.e*clipse said:Regarding the brake pedal error - this may be the same as the 68 pin ecu on a 1Z - The circuits sound very similar and the error is also similar.
When I installed the 1Z engine into my Toyota truck, I used the Toyota pedals and switches and ran into this error.
The clutch switch (F36) is a straightforward on/off switch that should be grounded when the clutch is off and open circuit when the clutch pedal is depressed.
The brake switch (F and F47) is actually two switches in one device.
F should be pulled to ground when the brakes are off, and 12V when the brakes are on.
F47 should be grounded when the brake is off and open when the brake is on.
You will get an error code (measuring block 6 on the 68pin ECU) if F, F36, and F47 don't read '0' (gnd) when the pedals are at rest.
Good luck!
One way to do this is to solder a resistor between the output and ground. This is done commonly with embedded computers and is called a "pull down resistor." When the switch is open circuit, the output will be pulled down to ground potential by the resistor. When the switch is closed, the voltage drop through the resistor will be equal to the input voltage.I'm having trouble seeing a way to pull F to ground when the switch is open then provide 12V when the switch is closed.
E*clipse,e*clipse said:One way to do this is to solder a resistor between the output and ground. This is done commonly with embedded computers and is called a "pull down resistor." When the switch is open circuit, the output will be pulled down to ground potential by the resistor. When the switch is closed, the voltage drop through the resistor will be equal to the input voltage.
The resistor can have a fairly high value ( 1000 ohms > 2000 ohms ) so the current through it will be minimal.
Are you using the Insight's switches? Does it use a double switch like the VW and Toyota?
- E*clipse
Mike,vwmikel said:Perhaps we could meet up sometime and try to get some of these issues ironed out. Are you using the cruise control with your setup? If Mark wants to contact me about it, that's fine. I basically just set it up to run like the 1.2L to get things off the ground, but there is definitely more work to be done and I'm sure some improvements to be made.
Jake, lets see what we can work out for this weekend. If you could, shoot me a PM and we'll try to figure something out.jpstaub said:Mike,
I'm sure a face-to-face meeting would be helpful plus it would give you the opportunity to check out/drive the car around. I'm free this weekend if you've got some time.
As far as trouble codes the last time I pulled them I got the following:
P0571
P1671 Definitely open since I didn't do any wiring for a pre-heat indicator
P1503 No load signal wired for
P0101
P1556.
Best wishes,
Jake
From the 1.2L/1.4L ECU diagram it appears F operates the same way. It appears to be a normally open switch (brake pedal released--open 0V, brake pedal pressed--closed 12V). So, my strategy was to parallel off the Honda switch (A32) to the F input (T121/32).
Dumb question: you did wire to the "output" of the F switch? If wired correctly, that should work. However, it's going to need a pull down resistor, because you need the F switch to change from GND > 12V. If it is just an open circuit, the computer may not detect the change. I've seen this happen w/ my PIC projects and my conversion.Something isn't working quite right. I'm getting no change in F with brake pedal movement in the F/F47/F36 advanced measurement block. F36 changes from 0 to 1 with brake pedal movement. I'm getting DTC P0571 Brake Switch (F): implausible signal.
F F47 F36
1 1 0 Brake pedal released
1 1 1 Brake pedal pressed
As a result of a World of Speed requirement for H rated tires I started looking in to what could be done with overall gearing through tire size. It turned out that I can achieve nearly the same overall gearing with a 175/70R14 tire. Presently I'm chasing down a set of Michelin Energy XH1's. They're supposed to be the berries in terms of low rolling resistance. I'm tempted to go even further with tire size to take advantage of the Insight's superior aerodynamic characteristics. If the 175/70R14's work as expected going bigger might be a thing to try. With the 175/70R14's I'm hoping for a 5-7mpg improvement on the highway as a result of a significant reduction in engine RPM at cruise.shortysclimbin said:I was soo going to do this a few years ago! glad to see someone else has. Can you give us more info on the technological hurdles... like how you regeared the tranny for the diesel and what you did about the ecu for the tranny/ car vs the ecu for the diesel? how did you get everything to play nice!? PS upgrade your batteries 150mpg should not phase you with a good driver and some programming on the system!
I'd love to hit this event but will unfortunately be away on business. Please keep forwarding events. Showing interested people the car would be a blast.06SpiceRedTDI said:There is a big get together in Portland, OR on August 22nd (TDI West Fest). Looks like about a 4 hour drive from Anacortes You should drop down and show your rig off. Sounds like the ultimate car, Honda reliability with A VW Diesel, you can't beat that.
http://forums.tdiclub.com/showthread.php?t=248544
tasdrouille said:For best highway fuel economy, you want the tallest tire that will fit in the wheel well, the skinniest one that can take the load, which will fit on the smallest steel wheel you can get for that size. Don't forget to shave the tires, the less material there is to bend as a tire rolls, the less the resistance. For disc brakes you should install springs to help pull the pads apart as much as possible.
What is the requirement as far as destroying the vehicle? Based on what you are saying, it seems you just have to destroy the shell and you can pull all the parts off that you wish?jpstaub said:I ended up buying a Lupo 3L in Munich and had it imported by a contact after getting the Federal DOT and EPA to buy off. Before you ask, I took the thing to the crusher last Friday to keep myself out of jail. Exporting the car or destroying it was part of the deal to import it. Ridiculous really but that's the way it works.
Having the whole car was quite helpful. I was able to verify many important steps in the build which saved a lot of time and effort. Additionally, I was able to pull a bunch of other parts (fuel cooler, vacuum canister, exhaust system, etc.) that were used during the build. In the long run I'm certain that although costly, working from an entire car saved me a pile of money in the end.
Because there is something called ventilation resistance, and steel wheels usually are best at that because of the simple way they are designed with the least area of openings. Isolating both sides of the wheel as much as possible.nicklockard said:Why steel, tas?
