arcking
I’m new to TDIClub and to VWs & TDIs, but looking forward to learning more. I picked up two project cars not too long ago – a 2004 Wagon with the 09ATiptronic (trans issues, ~160k) and a 2000 Jetta with the 5 speed (body damage). Originally, I’d planned (if possible) to swap the manual into the wagon but I hate to give up the ALH – if possible I’m going to try to get them both on the road.
I’m digging into the wagon now and trying to determine what the best course of action with the transmission issues. I’ve done a significant amount of reading on these issues online (09A Self Study, TDIClub, and others) and could use some insight with regard to troubleshooting and the decision as to whether to repair, replace with used, or swap a 5 speed. There don’t seem to be many cases online of 09As with no forward gears.
When I bought the wagon, the owner stated that it had been having trouble making it up hills without a running start and eventually lost all forward gears and had to be towed – it sat for some time after than until I picked it up. I’ve noticed that there is a very, very slight amount of ‘go’ in D, 2 and T1 but only on perfectly hard, flat, and level ground – and at that you might only get a mph or two at high RPM (essentially, no forward gears). Reverse on the other hand, works GREAT - no problems whatsoever. Fluid didn’t seem horrible, but certainly wasn’t new. Interestingly, once I was able to get it into T2 rolling down a hill and got about a second of solid engagement when I shifted back to T1.
I pulled the harness to the TCM at the transmission to put it in limp mode – the gear selection (PRND) went to a solid backlight as expected. With the harness unplugged, the car drives just fine in 4 and R. This would seem to imply that some of the components inside the transmission are in decent shape (K3, B1, B2, B3?) – thoughts?
I picked up a basic VAG KKL cable to read the TCM codes using VCDS 409.1 – here is what I got (with descriptions added where missing):
The sheer quantity of codes surprised me – would this be a result of disconnecting the harness? (It was reconnected for some time before these DTCs were pulled)
Does anyone have any insight into what might be happening? I know the 09A is notorious for solenoid issues, but would that result in the forward gears virtually being non-existent? If solenoids are/were the cause, how much damage could have been done to the internals before I picked the car up?
Is it possible to force the car into gears other than 4 and R in limp mode? I’d be curious to know if eliminating the TCM had any affect the other gears (with the hope of confirming clutch function/condition).
I’m planning to manually check the resistance across the solenoids and well as check for continuity to ground for each – ideally this would confirm the DTCs on the TCM, but with the ‘intermittent’ note I’m not sure if I’ll be able to see this with an ohmmeter unless I’m lucky. What else should be I checking? I’ve seen some reference to checking Measuring Blocks for the solenoids and pressures but I’m not sure what that would involve.
As another note – the coolant light displays on the dash when the car is first started, but goes after a few minutes. Additionally, the EGR cooler has a leak. Not sure if either of these would come into play, but I’d rather mention them just in case. Once again, this is 2004 Wagon with the BEW and 09A.
Code:
00264 - Solenoid Valve 4 (N91)
30-10 - Open or Short to B+ - Intermittent
00268 - Shareware Version. To Decode all DTCs [Solenoid Valve 6 (N93): Open or Short to Ground]
30-10 - Please Register/Activate - Intermittent
29-10 - Please Register/Activate - Intermittent
00262 - Solenoid Valve 3 (N90)
00258 - Shareware Version. To Decode all DTCs [Solenoid Valve 1 (N88): Open or Short to Ground]
00300 - Shareware Version. To Decode all DTCs [Transmission Fluid Temp. Sensor (G93) - Implausible Signal]
00349 - Solenoid Valve 10 (N283)
00350 - Shareware Version. To Decode all DTCs
38-10 - Please Register/Activate - Intermittent
00652 - Shareware Version. To Decode all DTCs [Gear Monitoring: Implausible Signal]
27-10 - Please Register/Activate - Intermittent
01045 - Tiptronic Switch (F189)
27-10 - Implausible Signal - Intermittent
