runonbeer
Maintenance EnthusiastVendor
Hi guys. We all know that auto G/J BEW cars eat axles almost as badly as a Passat. This seems to be a good solution to that problem.
I responed to burpod's WTB thread a while back about some 09A axles:
http://forums.tdiclub.com/showthread.php?t=481810&highlight=special+turds
The car I'm working on had all 4 boots blown and the inners were sloppy so I grabbed a set of these from Autozone. The price apparently has come down. They're $40/ea and the core is $5.
I'm not saying these are really super great axles, all I'm saying is that they're probably better than new Chinese axles. They appear to have OEM GKN joints on them.
Just a general FYI here. That is all.
I just picked up a set of the Reman axles mentioned in that thread and I thought I'd put up some pics.Seems like 90% of 09A cars that ever came into my shop already had a set of chaxles installed at some prior point.
Those 09A mkiv axles truly are some rare and special turds.
I found that Autozone carries a duralast reman version of both sides that does resemble the OEM shafts and joints. The boots leave something to be desired and I never gained enough experience with these parts to say whether the joints used aren't simply made out of the same chinesium butter metal like their full blown chaxle counterparts. It's at least not an expensive bet since these run under $70/ea. You do want to pull them out of the box while you're there and inspect. Sometimes it's just a regular new crappy axle I'm guessing they do this when they don't get an OE core back. I always reluctantly played the core game honestly and gave them the OE part I was replacing. I don't know why I always had reservations about letting one go since I wouldn't have anything better to do with it. The core charge is a pitiful $10 anyway.
Anyway, that's my experience.
