johnboy00
- Joined
- Jun 15, 2000
- Location
- Bridgewater,Ma.,USA
- TDI
- 2005 Passat Wagon, 2004 Jetta, 2003 Jetta wagon
I thought I was losing an axle for the second time in a year. My 04 Jetta completely stopped moving as my daughter was driving to school this morning. AS I was waiting for a tow, I took a look at it and saw that the axle wasn't rotating at all even though I could hear the transmission spinning and clunking slightly.
I saw this at ECS tuning describing an axle flange failure: If your flange shaft goes out, it is very likely that you will know about it. Either your vehicle will not want to move, or you could hear a thunking and crunching sound coming from the back of your transmission. If you are replacing the seals in your transmission, always inspect and replace anything that looks damaged or worn.
I don't see a lot of info about this. Is it extremely rare? How likely is it that this is the problem? It has been clunking a bit for a while. It got worse last night. In all cases the transmission was always working fine.
Does anyone else know if any other parts should be replaced along with this? Are any special tools required to replace it?
