4 TUGGIN
have a 09 Jetta TDI. Far as I can remember, when car was new the radio would stay on after the ignition was turned off and stayed on until key was removed from ignition. A few years later the radio turns off when the car is turned off and if the key is left in ignition the radio will turn on hours later by itself. Also dome light comes on and off by itself. Drained battery several times by not taking key out of ignition. Any ever seen or heard of this? Has to be some sort of relay linking this stuff together and letting them power up with key in off position but still in ignition. Any info would help!
