The NB just has the blue (cold) light in the cluster, and it goes to flashing red if overheating. The outside temp display is up by the mirror, along with the clock.
The NB uses the same temp sensor as the G/J, too. Once again, the cluster decides what it wants to display based on that input.
There are quite a few newer cars that do not have temp gauges, but instead employ the light strategy. Which is fine, you really only need to know if there is a problem, and a gauge creeping up may not grab your attention like a light would (and in many cases, if a gauge goes somewhere it normally doesn't, a light will come on anyway, or some alert, or something).
