pecosrunner
Ok, i changed the oil today and "Service Now" message still displays.Does anyone know how to "reset" the oil service interval counter???Thanks.
ROFLMAO. What you would get with that dealer oil change won't be free.2004STARWARSTDI said:I thought dealer did it for FREE?
no..i decided to do it myself at 9945 miles.I know its supposed to be for "free" but i always to all the oil changes on my vehicles myself.i like to leave it draining overnite...just my thing.Thanks for ur comments.2004STARWARSTDI said:I thought dealer did it for FREE? Are you changing oil too soon?
I thought these TDIs were Marine proof???Im not sure what mistakes u did, but its too late if i did the same....i changed the oil just under 10k by a few miles(by the owners manual)...approx 4.2liters Castrol 507 spec oil...OEM oil filter and i went ahead and installed Fumoto valve.i drained oil cooler from the top using an extractor...CMB430 said:pecosrunner!!!! Don't be a Jar Head! I am an Army Officer, so that was intended with a smile. Read my signature block link. I hope you are on target and did not make the same mistake I did.
I big OORAH! for u and airwolf..thanks for the help guys...I'll give it a shot in the morn.Windjammer said:ROFLMAO. What you would get with that dealer oil change won't be free.
pecosrunner, If you follow the instructions airwolf linked, be sure to wait for the odometer to go off before you start the process. It takes 30 seconds or so after you turn off the key.
OK..i dug and found that IT IS NOT.It clearly states to take it to the stealerhip or certified shop to clear message.It doesnt give instructions for DIY.velociT said:Not sure about the 09's, but this information will be in the owners manual.
If you don't wanna go digging through it, someone will probably be along soon with the procedure.
LOLjettafock said:place black electrical tape over the "Service Now" message. you shouldn't see it after that.
Did you try the method in the link in post#4? That worked for the '06 model.pecosrunner said:Ok, i changed the oil today and "Service Now" message still displays.Does anyone know how to "reset" the oil service interval counter???Thanks.
Sorry guys for not following up with this...yes, it worked.I followed the simple steps and it cleared the message.Thanks for all the help.El Dobro said:Did you try the method in the link in post#4? That worked for the '06 model.
