09-10 Touareg TDI VCDS measuring block 183 request
Sprocket
Sprockette's hubby
MI
2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
Would a few of you who happen to own or have access to a 2009 or 2010 Touareg TDI, please post your Measuring Block #183 from VCDS? I'd like to compare it to mine please.
Thanks for the help.
Sprocket
Sprockette's hubby
MI
Tom_B
Central Oklahoma
15 Touareg, 14 A6
2009 TDI, value for measuring block 183 is 1.06 (no units), same for engine on or off. Don't know what this is but hope it helps.
Sprocket
Sprockette's hubby
MI
Just curious, what is block 183?
Measuring Value Block Group [183] field 1 = SCR Learned Adaptation value
1.01 = Baseline (center) (not 1.00)
Acceptable Range = 0.90 to 1.10
A value greater than 1.00 = adding more reducing agent (example 1.20 = clogged injector, High DPF content, etc...)
A value less than 1.00 = taking away reducing agent (example 0.80 = leaking injector, etc)
Mine is 1.30 and I'm trying to figure out why and what needs to be done to fix it.
Springfield, VA
Very interesting! Good luck with the diagnostics.
