At low speed barely noticeable. Higher speeds pretty bad. Seems to be the left front causing it. I replaced worn pads and rotors and had a shudder before and after. Replaced caliper pins. Still there. Replaced caliper pin boots. Still there. Rotated tires and changed wheels. Still there. Replaced whole caliper and carrier because it was ratty looking. Shake still there. VAG COM confirms the antilock sensors are working as they should. Steering rack, tie rod ends, ball joints and control arm bushings seem fine with no play. I do hear what might be a slight bearing noise in the left front, could a failing wheel bearing cause these symptoms? Axle feels fine and is still OEM. Any ideas and thanks in advance.
