06 with 175k miles. Last summer lost blower motor and parked it. Got it out this week and After removing the motor found the seat heat fuse was blown. Replaced it and it worked! Went and bought a new battery and thought I was lucky. Then fuse blew again. Replaced it again and the the airbag fault lights up. Do research and read about washer fluid wires may cause this so I inspect them and rewrap them individual, replace fuse and drive it to store. Leaving store and start it up fuse blows and I get “engine fault workshop!”. So now I have engine fault, airbag fault, no blower and light bulb fault going on. So I take to local mechanic to read engine fault and when he plugs in his scanner he says there is no power to the the port. Then I noticed the headlights stay on when the key is on no matter what position the switch is in. It has never had drl’s. So I park it afraid it will totally fall apart if I keep working on it. Anyone ever heard of anything like this?
