Hrdc0r19
I was having dragging brakes, the pedal was falling, and I could only fix it by putting my foot beneath and lifting the pedal up. I fixed the issue by replacing the master cylinder and the brake booster. Now I have an implausible signal from the brake switch. I replaced the brake switch, the one on the master cylinder I don't have one on the pedal. Still have an implausible signal. I'm still pretty new to Vag-Com, but it looks like my switch is working. The warning lights are toggling on and off with the Glow Plug Light. The brake light switch goes to activate while pressed, but then goes to Non Operational when it's not pressed. Did I get a bad switch or is there a problem with my master cylinder? Why on earth did they move it from the pedal? My brake lights never turn off and I can't use the cruise control.
