06 jetta sunroof and trunk issues
dieselherb1
Va.
06 MK5,09 Mk5 CR,03 Mk4,96,2-97 B4s,98 A3,2000 A4,4 Caddies( 2-1.6TD,1.6,TDI) Chevys 6.2,6.5,6.5TD
just bought this car. trunk opened fine for a month now nothing with switch in door or key fob and handle inside the trunk! also inside light doesn't come on when drivers door is opened( this maybe same time as trunk won't open). Also sunroof doesn't do anything? Help Please!
R-Sixxer
Edm. AB
06 1.9L
Have you had your door wiring harness recalled or replaced yet? Pop the rubber cover off between the door and body and see if there are any cracked/broken wires. There was a recall on this part because the wires they provided were too short and would crack after X number of opening/closings. Unsure about the sunroof... good 'ol vw electrical gremlins!
dieselherb1
Va.
Found the problem with trunk, trim around the latch pin was holding trunk lid. Taking to pick a part next week get a couple of dome light-sunroof assemblies and try that
craig01b
Guelph, Ontario.
None
Sunroof switch has a ghost in it sometimes. I took mine apart, gave it a deoxit blast, and reseated everything, been ok for 6 months now. Reminds me I am driving a vw....
dieselherb1
Va.
I will check that. I see you fixed a door switch, driver's door? How did you fix it?
dieselherb1
Va.
Put in another sunroof switch, nothing! I checked the wiring at the switch no power! I checked the fuses first so ?
craig01b
Guelph, Ontario.
None
Do a search of 3 dollar door switch fix, tons of info. Replaced switch and its held in place with JB weld. No power to sunroof is different than most I have seen....
