Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K66M831xxx Mileage: 355930km-221164miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F3674337
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 6491A903025B0A6B239-8030
VINID: 0E69E290705B1867480C11851CC5F7C03B
5 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 355931 km
Time Indication: 0
Date: 2000.00.00
Time: 09:15:53
Freeze Frame:
RPM: 2583 /min
Speed: 33.0 km/h
Load: 100.0 %
Voltage: 13.91 V
Bin. Bits: 00001000
Absolute Pres.: 1897.2 mbar
Absolute Pres.: 683.4 mbar
000305 - Oxygen (Lambda) Sensor B1 S1
P0131 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 355932 km
Time Indication: 0
Date: 2000.00.00
Time: 09:17:14
Freeze Frame:
RPM: 2394 /min
Speed: 30.0 km/h
Load: 100.0 %
Mass Air / Rev.: 265.0 mg/str
(no units): 0.20
(no units): 0.0
Bin. Bits: 10001001
005269 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00001000
Mass Air / Rev.: 855.0 mg/str
Mass Air / Rev.: 0.0 mg/str
001026 - EGR System
P0402 - 000 - Excessive Flow
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 355933 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:52
Freeze Frame:
RPM: 1302 /min
Speed: 10.0 km/h
Load: 19.2 %
Duty Cycle: 100.6 %
Duty Cycle: 95.1 %
Mass Air / Rev.: 290.0 mg/str
Mass Air / Rev.: 10.0 mg/str
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00001000
Torque: 122.0 Nm
Torque: 107.4 Nm
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000603130270
Coding: 0000020
VCID: 51FF70D76DE98FC378F-8004
3 Faults Found:
28775 - No Communication with Gear Selector Module
U0103 - 004 - - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 255
Reset counter: 0
Mileage: 0 km
Time Indication: 0
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 0 km
Time Indication: 0
16947 - System Voltage
P0563 - 000 - Too High - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 355933 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71BFD057CDA9AFC358F-8024
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
001 - Upper Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6889BD33FE736E0B0F1-803C
1 Fault Found:
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000330268
Coding: 14010E234004150000140000001400000008730B5C
Shop #: WSC 22232 444 85641
VCID: 2A0D073B20FF9C1BD95-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 22232
6 Faults Found:
01497 - Bulb for Blinkers; Front Right (M7)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 355573 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 118
Reset counter: 53
Mileage: 337906 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.80 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 355933 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 17.75 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 93
Mileage: 355933 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 6.15 V
OFF
ON
OFF
OFF
OFF
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 355933 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 17.15 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 93
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 5.00 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F1026144
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 93
Mileage: 355933 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:58
Freeze Frame:
Voltage: 18.50 V
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 53
Mileage: 355933 km
Time Indication: 0
01304 - Radio
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 355933 km
Time Indication: 0
Date: 2000.00.00
Time: 01:09:21
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD05EJ5$
Coding: 0013113
VCID: 392F2877D5592783A0F-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME10413C462
Subsystem 3 - Serial number: 6342MSME0E37355CL
Subsystem 4 - Serial number: 6351HSME094D1D108
Subsystem 5 - Serial number: 6361HSME09525602/
Subsystem 6 - Serial number: 63727SME095E18030
Subsystem 7 - Serial number: 63827SME0957406C4
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78A9ED73AED3FE8B9F1-802C
2 Faults Found:
015 - Cannot Be Tested at this Time - MIL ON
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 953 D
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 22753 067 57207
VCID: 2C0101232A0B822B2B9-8078
4 Faults Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
01315 - Transmission Control Module
01316 - ABS Control Module
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001063150319
Coding: 3F3F0B60071002
3 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 53
Mileage: 312717 km
Time Indication: 0
Date: 2000.00.00
Time: 18:26:58
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 93
Time Indication: 15
Freeze Frame:
Fault Status: 01100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 53
Mileage: 355933 km
Time Indication: 0
Date: 2000.00.00
Time: 00:20:01
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3635234BE447C8FB4DD-8062
3 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 34311943F23BDAEB739-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74B1D943B2BB9AEBB39-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
4 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2E4FE34D31F356B-8062
3 Faults Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F10570D29EFC318F-8064
2 Faults Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1F5B082FD4DB615-8066
2 Faults Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070C2711118B233C7-8078
No fault code found.
End----(Elapsed Time: 01:21, VBatt start/end: 10.1V/10.0V. VIgn 10.0V)-----
Address 46,1K0 959 433 AF,recoded (Long Coding),from,137803281B09058F880F048051A0,to,1AF803283B09058F880F048051A0,(00066/000/00000),
Address 09,3C0 937 049 D,recoded (Long Coding),from,14010E234004150000140000001400000008730B5C,to,14010E234004150000140000001400000009730B5C,(22232/444/85641),
