BadNewsMike
06 Jetta BRM 109K cyl 2 Misfire
So friends car. asked me to look at it.
2006 BRM TDI with 109k, first brought it he said it died on the road had it towed here. this is by no means a idiot. he snapped a t-belt on his AHU and redid the head himself. he was stumped on this though.
he admits to using old diesel in the car and it died. so he pulled the in-tank pump, and the filter replaced filter, cleaned mesh on intake pump, pumped out the old diesel fresh tank of new. and drove the car for another 3-4k before it started acting up. randomly dieing not wanting to start when warm. long crank time, then it finally died. had it towed to me.
So engine has 400+psi all cyl good sign.
I got the car running but its missing on cyl 2
I pulled the line after the filter and ran cleaner right threw. still a mis on cyl 2 pulled valve cover a little where on the cam shaft, (but would that make it mis completely? and wouldn't that effect compression)
tested the injectors same resistance across all of them, check continuity threw the harness no issue there (not surprising the ONLY code is mis-fire there is NOT a code for the injector as i have seen in slimiler threads Ive searched.)
so its down to either the cam is worse then i see or the injector is in need of replacing.
If i drive the car on the mis. it will stall and not want to restart. could there be a bigger issue im missing?
also the IQ's are cyl 1 2.00, cyl 2 2.80, cyl 3 -2.00 cyl 4 -2.00
or something like that. I can pull exact numbers if its needed.
Have vag, and 10 years working as a tech. the BRM is a little foreign to me as NY banned them. so I mostly see ALH and older.
