Hello all,
as the title suggests my 06 BRM finally is getting a replacement cam, it has 224k miles on it, and I’m presently in process of replacing the cam, turbocharger, and a bunch of other (mostly little) things I keep finding as I’ve been tearing it down. I’ve hit a point where I probably should have just bought a wrecked 2.0CR car for parts and engine swapped it but I’m in too deep now to turn back...
I’m replacing the cam with an AMC unit, my budget doesn’t allow for a Franko6 or Colt cam or I’d have gone that route. I’ve inspected the AMC cam on a surface plate and it’s within ~0.0005” end to end and the surface finish looks fine, so I’m rolling with it. It will be slathered in Joe Gibbs assembly lube and broken in with their break-in oil as well. I’m using the Franko6 solid bolts in the cam caps and rocker axles, and I will most likely be drilling the cam caps and/or modifying the Glyco bearing shells as well.
Here are some photos of the cam, lifters, and bearings I pulled yesterday.
Here’s a shot of the injector rockers, it’s hard to tell from this photo, but there is some scoring on the rollers that I can feel with my nail and will need to be polished out before reinstallation.
I’m a bit concerned with how much wear the cam and lifters have, about the amount of metal that potentially has gone through the oil pump and what its internals look like, has anyone torn down a BRM oil pump after a cam failure to check it for damage? Do the oil pumps typically take damage from these cam failures, or are the metal particles usually small enough to not significantly impact the internals of the oil pump?
As for the seemingly ever growing list of other stuff being done/replaced, the stock BV39 turbocharger had 0.016-0.019” radial play and 0.003” axial play measured at the nut on the compressor side, and I found a great deal on a brand new PD140 turbo upgrade kit so I opted for that.
The tandem pump has been slowly seeping diesel between it and the head, and I think the drivers side back corner of the valve cover was weeping some oil as well, so the transmission dogbone bushing is shot, one of the EGR coolant hoses was mush, and I noticed the trans dogbone bushing in the subframe is dry rotted/cracked/sloppy too, so all that is getting fixed.
Typical EGR cooler leak around the flap shaft, will be getting welded and will never leak again. I’d delete it but it’s cold here 6 months out of the year and I like fuel economy.
intercooler and charge piping has more oil residue in it than I’m okay with, so I’ll be cleaning all that out.
I have a new thermostat and other little things I’ve been putting off, like shifter cable bushings etc, so I’m doing that too since the exhaust is off.
I’m also taking the opportunity to install a FrostHeater, partly because I’ve wanted one for a while and partly so I can preheat the engine and the oil before the first fire so it’s all up to temp for the initial break-in, and the rest of the first 500 miles of break in and beyond as well. 15W-50 break-in oil and ~30°F or less temps is a no go.
I plan to clean the intake manifold and EGR system, and maybe walnut blast the intake ports, unsure how to accomplish that yet but I have a few ideas...
I’m sure I’m forgetting stuff, it’s late here and I’m tired. I will likely update the thread with more pictures as I go along, this has become a much longer and more involved project than I anticipated, none of it is beyond my capabilities, just time consuming, frustrating, and I feel like every time I take something apart I find another thing I need to order or dismantle to inspect. I’m super meticulous and have another car to drive at the moment so that’s not helping matters either...
