Brosaki
So want to get a malone stage 4 tune but for that i need a bigger turbo, any recommendations? And also if youre in pa. If i put a hoodstack on it will it pass inspection?
Yep...sure is. Going rate is OTO $1200. Working my way into justifying this as a PM item. Replace before one fails and melts a piston sounds like a fine idea. 1043's here I come... Or maybe just get DLC800's...LOL With the same philosophy applied to a VNT17 replacement for a KP39.For a vnt-17vb, BEW stock injectors are fine. Going with bigger injectors is expensive on the PD platform.
Thank you manIf you're going to get a bigger turbo you might as well do it right the first time imo.
I'd recommend getting one of these depending on what your budget is and how much power you would like to make in the end.
GARRETT TURBO GTB1756VK 6+6 BILLET WHEEL
GTB2060VKLR VKLR
GTD1756VRK
GTD1752VRK
Then you can get a used set of PD150 nozzles pretty reasonable from a few different places.
You'll have call to see what Chris has in stock or can get. https://www.korwerksllc.com/
https://www.uniteddieselshop.co.uk/vag-19lt-tdi-pd-set-of-4-injectors-745-p.asp
https://www.darksidedevelopments.co...di-pd150-arl-injector-set-038-130-073-al.html
I'm sure there'll be some other parts you'll need along the way that I'm forgetting, but that should get you started.
I guess it all depends on what turbo you go with. If you go with a VNT-17 or even a VNT-17/22 you could run a smart actuator, but if you're going get one of those turbos you're going to need to get your car tuned to take advantage of the new turbo. The tuner would also be able to tune out the need for a smart actuator, so you could then run just about any turbo you want really.I can't tell from the pictures in the links above, but the 1.9 BEW replacement turbos all have electronic ports/ smart actuators? I was looking at a replacement turbo from gottuned.com in Poland and asked me if my turbo has a standard vacuum actuator (not electronic). This confused me because I know many replace their KP39s with VNT 17s and from pics I have seen, there looks like there is a port on the actuator meaning its the smart actuator. I know over in europe they deal alot of different diesel variations. I believe I need to have the smart actuator for US 2004 VW 1.9 TDI BEW? Not a standard vacuum actuator. Found your post searching for replacement turbos... mine died...lol
