TokenRednek
Im not sure where to really start with this issue so ill just post my VCDS scan results.
Sunday,18,August,2019,10:38:08:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 396170km-246168miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 N HW: 028 101 198 2
Component: R4 2,0L EDC G000SG 1388
Revision: 12345678 Serial number: VWZ7Z0D0106612
Coding: 0000000
Shop #: WSC 66565 257 00032
VCID: 295E26E6836262099E-513C
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 05314
VCID: 53A2A40EA16E08D904-515A
1 Fault Found:
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 244037D2B440BF61AD-513C
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 00000
VCID: 275A20DEC576547988-513C
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: 70E80B82303853C119-513C
Address 46: Central Conv. Labels:
VCID: 55A65A16AC9A16E9EA-4B00
Note: Excessive Comm Errors
The main issue im having is the ASR light is constantly on. ive driven the car about 20 miles since the recode and retune and its still on.
the car has the 5.3 Bosch ABS unit and does not have the steering angle sensor. My soft coding is a 00012 for a diesel and manual with canbus.
ive attempted to recode the CAN gateway as well to relearn the modules after coding but there is some step im missing to get this to go away.
Anyone with any help? Also, notice my central convenience says excessive communication errors? what is that about? i did do this scan with the car not running
www.Ross-Tech.com
Coding: 0000000
Coding: 00012
Shop #: WSC 05314
1 Fault Found:
Coding: 12345
Shop #: WSC 05311
Coding: 15235
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 05311
