05 Passat - Slight hesitation under acceleration
JBjunior
WA/NC
05 Passat Wagon/05 Passat Sedan/03 Jetta Wagon
I don't drive this car very much, my wife does, but I don't think the problem existed before the latest maintenance. About a week ago I changed the fuel filter, air, filter, cabin filter, and oil/filter. My wife drove the car the next day and called me to say it hesitated while climbing a hill. Sure enough, I have been driving it off and on since and I will get a slight hesitation at certain points.
From stop and driving normal, no hesitation. From stop and getting on it, no hesitation. If around 45 and/or around 1500 - 2300 RPM I give it a more than normal press of the accelerator it will hesitate like it isn't getting enough fuel/air and then power through. On flat I can get it to the point it almost never does it but while going up a steep hill I can get it to do it around that same RPM and again at higher speed 60+ and pushing the accelerator to the floor. Starts fine, idles fine.
I went back through the air filter change and verified everything appeared to be good. I replaced one of the fuel lines that had some potential deterioration and I have tried multiple different types of clamps on the fuel lines trying to rule out air leak there.
I unplugged the MAF and I didn't see much difference at all. VCDS, other than after unplugging the MAF, shows no related codes. Otherwise, not sure what else to look at. I see mixed information about cleaning the MAF, some say not to and others saying it is ok to clean.
Where should I look next?
Mozambiquer
Versailles Missouri
What is the torsion value?
Sent from my S60 using Tapatalk
JBjunior
WA/NC
It is set at -1.5. I will upload a picture in a few minutes with some other information I just grabbed that may be relevant, or not.
Also, and it is infrequent, it does have a small idle fluctuation of about 20 RPMs.
Mozambiquer
Versailles Missouri
Ok, that doesn't sound too bad. I think optimum is around 0, but if it was way off, that could signal a worn camshaft. It may be good to check that if you haven't already, since that can cause the stumble. I know the brm in the 05-06 Jetta had a common issue with the turbo vanes sticking thus the zip tie mod, I guess that could also happen with the 1749 turbo...
hipavlos
Bellingham, WA
2005 Passat GLS Wagon TDI x 2
Picking up this thread. Did you come up with a solution to this problem? I bought a second ‘05 Passat TDI that is having the same problem. Has been fine driving around town for a few months. Today heading out on a road trip and is hesitating/stumbling slightly while accelerating up hill at freeway speeds.
doxster22
Greensboro, North Carolina
2004 Passat TDI, 2000 VW Jetta TDI
anyone have any solutions/resolutions to this issue. I picked up an 04 Passat TDI doing the exact same thing. Pulled valve cover and cam looks good. I'm suspecting a worn injector or leaky injector.
DeliveryValve
Western US
Passat GLS Wagon
I read somewhere that someone inadvertently swapped the feed and return fuel lines to the fuel filter which caused a stumbling issue. They noticed the mistake, corrected it and all is well.
doxster22
Just tried that with no luck. Makes the problem much worse but now I at least think that it is a fuel delivery problem. Symptoms are more severe with lines switch, maybe not flowing enough fuel?? It has a brand new OE fuel filter.
