What current rating in AH is her brand new battery? The BRM OE battery is 80 Amp Hours (AH).
from Varta website
Ampere hours [Ah]
Product of the current strength (measured in amperes) and the
duration (in hours) of the current. The quantity of electricity
(capacity) of a battery or cell is usually expressed in ampere hours.
Ah is the abbreviation.
Cold Cranking Amps [CCA]
Cold cranking is the discharge current given by the manufacturer.
It is emitted by a battery at a temperature of -18°C with a minimum
voltage of Ui=7,5 volt for a period of 10 seconds, according to the EN
specifications.
The reason Ah is important for the TDI is the current drawn by the glow plugs on cold start. This occurs just before the battery is also called upon to turn over a cold, high compression engine. The glow plugs draw about 50 Amps...
A battery with high CCA may not have the AHs required for the demands of a diesel. Find out what the Amp Hour rating is for the battery. It may be for the gas Jetta...
More reading at
http://forums.tdiclub.com/showthread.php?t=58342
