Slowassjetta
So my 05 BEW Jetta jumped timing a while back. Just got the car running again. The problem is the car stars right up (even on the cold days here is WI) can hear the turbo spool up and car revs to any rpm you want but under load has no power. Boost spikes at like 23 psi and holds a steady 15 psi Car has new head,MAF,n75,turbo actuator, fuel filter. No vacuum leaks. No codes either. Intake and egr valve were cleaned when off. Also is straight piped so clogged cat is outta the picture! Any help is appreciated I miss driving this car.
