eluwak
Ok, I'm going to try to do this a little better than I have in the past but bear with me... Let me know what you guys want to see in here if I miss something
How to search the forums -> http://forums.tdiclub.com/showthread.php?t=133579
FAQ:
Timing Belt Change Interval? -> http://forums.tdiclub.com/showthread.php?t=171926
Break-in Period by Drivbiwire -> http://forums.tdiclub.com/showthread.php?p=464223
DIY Service:
Service the DSG -> http://forums.tdiclub.com/showthread.php?t=169356
Fuel Filter Replacement -> http://forums.tdiclub.com/showthread.php?t=175046
Oil Change -> http://forums.tdiclub.com/showthread.php?t=169124
Pollen Filter Replacement -> http://forums.tdiclub.com/showthread.php?t=145852
Wiper Blade Replacement -> http://forums.tdiclub.com/showthread.php?t=143882
Adjustment procedure to correct Jetta high beam aiming problem -> http://forums.tdiclub.com/showthread.php?t=169800
Fixing the rough idle problem -> http://forums.tdiclub.com/showthread.php?t=215202
P-D cam wear fix? -> http://forums.tdiclub.com/showthread.php?t=253137
DIY Mods:
Auxilliary Input using PIE VW02 and SAT Passthrough -> http://forums.tdiclub.com/showthread.php?t=175146
Under Seat Drawer Install -> http://forums.tdiclub.com/showthread.php?t=169765
Remote Windows -> http://forums.tdiclub.com/showthread.php?t=109405
VAG-COM Tweaks -> http://www.ross-tech.com/vag-com/cars/Golf5.html
Speedo Calibration -> http://forums.tdiclub.com/showthread.php?t=158652
MPG adjustment -> http://forums.tdiclub.com/showthread.php?t=111362
VWVortex A5 FAQ/DIY:
http://forums.vwvortex.com/zerothread?id=2374154
FAQ:
DIY Service:
DIY Mods:
