05.05 nb bew auto axle interchange
Stafford Virginia 22556
96 glx variant tdi
I'm looking for axles to replace the current Chinese ones. I can't find any other mk4 axles that are the same, neither jetta nor golf. Can anyone advise if other mk4's use the same axles ? Thanks.
Not in the US. A4 FWD DSG only. Ane the OEMs went NLA about a decade ago.
I'd ask Raxles if he has any info on this, because you are not alone in the problem. The OEM ones probably could have been rebuilt multiple times over, but once they got scrapped and the Chaxles installed, you're kind screwed.
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
Didn't save your originals? There have been a few people parting out DSG beetles. Nothing else will work.
The irony here is about all the 2-pedal BEW NBs are good for are 5sp swaps, as no DSG-related bits are available for them anymore, and they are too unique to use anything from something else. Even the M-unit is its own specific part (although those are NLA for even more of the common ones now, too, so....)
bigsexyTDI
Kentucky
'98 NB, '04 Jetta
That is unfortunate to read indeed. I am always on the lookout for unicorn low mile New Beetles (old folks vacation home car, etc) and thought that if it happened to be a DSG BEW I would be ok with it, but now not so much... bummer.
csstevej
north nj
What about some of our vendors over seas?
Mystery to me why the BEW NB got the DSG, and the BEW G/J got the Jatco. But, the packaging of the Jatco is such that they had to run the engine/trans harnesses differently, which meant the battery tray in them sits UP an inch or so. This difference may have just been incompatible with the NB as it was already unable to have the H7 battery as it was. And with the diesel, they didn't want to do what they did with the TT and make that on-off goof ball tiny battery the fitment. Because the 02E DSG despite having six speeds, is dimensionally smaller than the 09A Jatco five speed.
But then it begs the question: why didn't they just use the 02E in ALL the BEW applications? The Jatco is kind of rare. It was only used behind the BEW in the G/J and behind a few 1.8t and VR6 engines (VERY few... as I've never even seen one behind a VR6, and only two ever behind the 1.8t). And what makes the argument even worse for the Jatco: they were also using the 6sp Aisin box behind some engines, even back into 2001, as the FWD 1.8t TT got them, as well as some of the 2002+ 2.slo NB Convertibles (just the 'verts, not the hard tops ???? ).
Volkswagen is weird.
gforce1108
Newburgh, NY
Unfortunately - I've been acquainted with a 1.8T 09a too well... 1.8T 2005 GTI came with it. I did a trans service with the timing belt at 100k. Around 140 it started having some shifting "issues". Kid kept driving it delivering pizzas. False neutral in 3rd, then slam and chirp the tires. No codes in VCDS. Tried a set of solenoids and a fluid change - no improvement. Found a used $200 "yard tested" trans and swapped it with the TCM, still no 3rd. He sent it to auction. I pulled the new solenoids out before scrapping it at least.
boertje
Coeur d'Alene, ID
'01, '01, '03, ‘06 NB - TDIs all.
Even if you had the original axles, replacing the inner and outer joints is cost prohibitive if one can even find those. At least the boots are common.
This is where a call to the fellow at Raxles may help, as he may at least know if the splines on the inside of the shaft are the same as something else. The outer joints, and thus the outer splines, are all the same (02J, 01M, 09A, 09G, and 02E). It is the INNERs that are different. The 09A, 01M, 09G, 02E, and some of the very late 02Js bolted to the 1.8t engines all use the tripod style inner plunge joint, but they are slightly different. And some of the tripod style joints are peened over and prohibit easy removal of the outer housing of the joint.
There may be a case where some other shaft/joint combo could be assembled to work with these unique applications.
boertje
Coeur d'Alene, ID
I have the outer joint as DSG outer cv joint 1km498099a but taking the same outer boot as the 02m axle. Are you sure about that “outer splines, are all the same (02J, 01M, 09A, 09G, and 02E).” Was wondering if the 02m outer joint might work but can find no info.
I thought all the [4 cyl] outer joints were the same. If they are not, then that's news to me. But admittedly I've not even seen a DSG NB in quite a while, and my ETKA machine went TU earlier this year so I cannot look things up like I used to be able to.
I know some TTs use a different outer joint, as they bolt in (like the A5+ cars and B cars) instead of a big nut. But the bearing is the same.
VAG tends to mix 'n match things, and they revise part numbers all the time too (a 1Kx prefix is for the A5, not the 1Jx most NB mechanicals would be). And as I said, the A5s bolt in.
I only see the same old 357 prefix (so, back to the B2 era) 36 spline outer joint when I look them up, but it isn't from ETKA so that may be in error.
boertje
Coeur d'Alene, ID
A call to raxles yielded no info on shaft splines, etc. Said he could rebuilt oem shaft for $349 though. Last one he did was a year ago for a 2005 bew dsg bug.
mittzlepick
union maine
2004 jetta wagon (365k)2001 wagon tire burner 6spd 2003 wagon(417k)
Try the vortex? Maybe there was a gas bug with same offering? Or if so order for that combo or lookup as that from somewhere like ra?
96 glx variant tdi
I posted on vortex and am receiving the same scams I get here. I'm trying to find an oem set, not another chaxle set to replace my current chaxles. I can see this is going to be a game of patience. Thanks for the suggestion though.
96 glx variant tdi
These are typical of the scammers messages. They create an account, immediately contact folks looking for a part, hopefully they get reported and booted, then they're gone. These may have come from vortex, but the ones on tdiclub are similar... all gone like smoke though, not even a trace in the email box.
vayahak started a new conversation with you at Axles
Hello buddy I can recommend a uncle who have an oem axles for a 2005 nb with the bew engine in good working order pm him on autocarpartworkshop@gmail.com if you still looking Sent from my iPhone using Tapatalk
diweped5 started a new conversation with you at L&R axles for bew / dsg combination
Hello, Gonzalez as a L&R axles for bew / dsg combination, available for sale, pm the g mail below to reach out to him. Gonzalezanastasiatony@ gmail. com Cheers. Sent from my iPhone using Tapatalk
Yeah, the Intarwebs are chock full of these wastes of flesh. Really sad how many useless dirtbags there are among humans.
boertje
Coeur d'Alene, ID
Just for kicks i contacted darkside in uk concerning these axles. Their response.
“Just chased my local supplier, and they cannot get these part numbers.
They're telling me it is a different market so impossible to order.
Nobody in the aftermarket also makes the axles or joints.
Unfortunately they is nothing we can do on this one. “
96 glx variant tdi
Thanks for the try. It's just my luck to buy the rarest of the rarest unicorn new beetle vw ever made. That makes two vendors who can't help, Dutch Auto Parts and Darkside. Does any one know which country these beetles were exported/imported to ?
boertje
Coeur d'Alene, ID
They were made in mexico for the north american market apparently. Axles are velcon (gkn??).
I sent a query to the gkn north america rep to see what they know.
boertje
Coeur d'Alene, ID
So, i just acquired a NOS oem 1J0-407-272-MJ right side axle for the bug bew dsg yesterday. Unfortunately it was the only one. The outer joint is stamped with 1J0407311AK, the outer boot is marked as 1K0407285K (which is the same as what is used with the 02M axle outer) found here. The only difference between the outer joint kit for the 02M axle and this dsg is the actual cv joint. The dsg cv joint is 1J040731AK and the 02M is 1J040731AJ. I haven’t been able to determine what the actual difference is.
The inner joint caught be by surprise. It is stamped with 3B0407341B which appears to be the same part number aka 1K0498103EX, 1K0498103E. It is found here. The boot kit then would be this as its the same inner joint as the dsg mkv, mkvi uses. The original inner boot kit for the bug bew dsg is this.
I used the rein inner boot kits on my old original axles so i know they work even though the part numbers don’t line up.
Hopefully this helps and/or someone has more info to add.
