I need some opinions on what can be causing this idling noise I'm hearing. Sounds like it's coming from the fan area of the motor (chirping type noise), and it goes away when the rpm's go above 1100. The belt seems to be vibrating quite a bit when this is happening. Also, when I turn the wheel hard, it sounds like the belt is also making a slipping noise. I've replaced the belt, clutch fan bearing, belt dampener, and most recently the power steering pump. Any opinions on what else it could be would be greatly appreciated. The car has 74,000 miles one it, and has been flawless. We are an all diesel family. Wife's 04' Passat TDI, older daughter's 99' TDI Bug, younger daughter's 98' TDI Jetta, and I drive an 05' GMC Sierra Duramax! Thanks in advance for your help.
Carmen
Carmen
