pruzink
My 2004 BEW PD Jetta has developed an intermittent stalling at idle problem. This doesn't happen very often (maybe 1 out of every 50 times that I am stopped with the car in drive at a light or traffic). No codes are being set. I have a 2 micron Cat fuel filter which I change once per year. After the car stalls it starts right back up and runs fine. The car has 146,000 miles & I do plan on pulling the valve cover soon to inspect the cam & lifters; but I do send oil samples out for analysis and so far the wear metals look good & the last time that I looked at the camshaft (about 20K miles ago) it looked good.
I did a search on here & posts that I saw as potential culprits were the crank sensor, the in tank fuel pump, camshaft wear. I will be paying attention to see if this only happens when the air conditioning is on. When it does happen, the car RPM at idle are steady & it just dies with no reason.
