What's the secret to breaking into the door without too much damage to get it to open ? Not program or handle related, something must have come loose inside the door. Thanks.
I had a similar issue on my 03 Jetta (non wagon though). Rear driver side door wouldn't open from inside or outside. What happened was that the release cable that goes from the inside handle to the door lock got unhooked somehow.
What I did was getting another door handle from pick and pull and then I cut the handle on the car a few inches from the right side. I could then pull the smaller piece on the right out of the door and that gave me enough space to insert a hook (made from a metal door hanger) to release the lock. Check out this video for more info:
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
