McGuillicuddy
Quite suddenly in the middle of a long trip I stopped being able to shift into reverse when I stopped at a service center (fortunately I was on the way home!). All other shifting is smooth. The shifter feels fine otherwise. There is no grinding or drama of any kind. I depress the shifter and push it to the left but it simply won't push up into R.
Some relevant info:
I can wrestle it into reverse occasionally with a good deal of wiggling and a bit of force, but it takes a long time, and most often it won't go.
I had a Sigma 5 Short Shifter installed when the problem arose but swapping back to the factory shifter makes no difference.
When I detach the shift cables I still cannot shift into reverse by manually manipulating the shifter linkages, so it feels like the problem is in the transmission, not the shifter/cabling.
Absolutely nothing happened to precede this. All was well until it wasn't.
Clutch (IDParts Quiet Clutch) and transmission fluid was recently done (~ 2 months ago)
Any thoughts? Car only has about 90K miles on it so it would be odd for something to be worn out inside the transmission, but who knows.
Some relevant info:
