travis017
Working on a 03 tdi automatic and it won't stay running. If you keep your foot on the throttle it will run but as soon as you let off it dies. Scanned with VCDS and came up with these codes. Any ideas?
Tuesday,05,August,2014,15:48:33:53535
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWRP69MX3M068557 License Plate: DELLTDI
Mileage: 307390km-191003mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWRP69MX3M068557 Mileage: 307390km/191003miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000AG 4308
Coding: 00001
Shop #: WSC 00066
VCID: 62C1524EEE9EAE0EED3-4ACE
3VWRP69MX3M068557 VWZ7Z0B5140635
1 Fault Found:
16705 - Engine Speed Sensor (G28)
P0321 - 35-00 - Implausible Signal
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 MK
Component: AG4 Getriebe 01M 5023
Coding: 00000
Shop #: WSC 00000
VCID: 850BE9D29FF0B936281-0958
1 Fault Found:
00529 - Engine Speed Signal Missing
35-00 - -
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 336FE70A51E47786565-5102
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 2757035AC53C0B26FAD-50E6
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 M
Component: KOMBI+WEGFAHRSP VDO V62
Coding: 07232
Shop #: WSC 00000
VCID: 3261E20EFEFE7E8E5D3-50E6
1 Fault Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0E5A806B0728C9EEB7-50E6
No fault code found.
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 3777D31A159C9BA66AD-4AE6
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0004
2 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00914 - Window Regulator Switch; Rear Left; Driver (E53)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio ZSW 0012
Coding: 00031
Shop #: WSC 00066
VCID: DDBBE1B257E011F6501-50E6
End ---------------------------------------------------------------------
75 76
Coding: 00001
Shop #: WSC 00066
1 Fault Found:
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Coding: 0004097
1 Fault Found:
Coding: 12340
Shop #: WSC 00066
1 Fault Found:
Coding: 07232
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
Coding: 00258
Shop #: WSC 00066
2 Faults Found:
Coding: 00031
Shop #: WSC 00066
