03_blue_jetta
Hi guys - new to the forum, but wondering if I can get pointed in the right direction.
I was driving on a medium speed road (80km/h or 50mph) and my 2003 Jetta TDI engine cut out. Very smoothly, no loud noises or strange vibrations. Just no RPMs. I hit the clutch while coasting along and restarted the engine. It ran only briefly then cut out again. This repeated maybe two or three more times until it just wouldn't start. My first thought was dirty fuel filter, but nope - that's not the problem. After I towed it home, I borrowed an ODBC-II reader and got two codes off of it:
P0251: cam shaft position sensor malfunction injection pump A rotor
P0401: exhaust gas recirculation flow insufficient
I want to try and save some money by replacing the cam shaft position sensor myself, but I'm pretty far from being a mechanic. First challenge is to find where that part is even located. So I did some google searches but only come up with pictures and YouTube videos from different model years - and yup - my 2003 TDI looks different from, for example, the 2006 TDI in the video so that's doesn't help enough.
In my little bit of research I learn these TDI engines have names like "BEW" and "BRM". Mine, being a 2003 does not seem to be either of those names. Not sure what mine would be called? The car VIN (for what it's worth) is 3VWSP69M23M149599
I guess I want to know where this cam shaft sensor is located so I can replace it. But also, it seems everyone on this forum is so familiar with these engines maybe you guys can weigh in: based on the P0251 code am I daydreaming when I think my problem is limited to just the sensor? Or is this just the tip of a much larger iceberg? Any savvy advice I should be listening to?
The car is pretty old and has some other issues so it's not worth too much, so I'm not willing to put in a great effort to resurrect it.
