sgtpopeye43
Hi Folks,
Three years ago I increased the pressure in my O1M transmission, this is called the Kerma Mod. I went too far and soon after while using my ScanGauge I noticed very high trans temps and trans slipping when the temps were over 240 degrees F. There were times that the temps went up to 290!! Meanwhile I have only used this car for short trips as result. This all changed during that last few weeks as my wifes 99 Windstar was condemmed during a Ford recall inspection for subframe failure. we accepted the offer from Ford and got a check in less than a week.
Buying another or new car at this time wasn't an option for us. So back to the Jetta as it is my 2nd car besides my one ton V10 Ford van gas mileage special!! HaHa!!! I had to do something quick and after calling 5 or 6 places that recondition valve bodies I found one that had an O1M valve body in stock and I ordered it. Yesterday I installed it and the new harness that I ordered with it and all went well. The 2-3 upshift was somewhat problematic but after putting 100 miles on it today and rechecking the fluid level after it cooled down enough it operates fine. Now my wife has a car to drive and she adapted very well to the VW and TDI.
So as CoolAirVW always asks, if you post a problem then post the resolve and here it is although taking three years to get it done. I would have sent the valve body to CoolAirVw to rework but time didn't permit.
I still need to check if there were any trans codes and get them cleared if there are any. Hopefully the valve body rework will give this O1M more life, but time will tell. The car has 93,400 miles and the timing belt was replaced two years ago at 82,000 miles. No I gotta do some brake work, but I can handle brakes!!!
Bob MacGregor in Ct alias SgtPopeye43
