fourwarner
Recently, when parking on a hill our 2003 Jetta with 80,000 miles will roll back like the engine has low compression. It runs just fine and has plenty of power. Any ideas on what could be causing this problem ?
Your parking brake is not being applied or the cables are tooefed.Recently, when parking on a hill our 2003 Jetta with 80,000 miles will roll back like the engine has low compression. It runs just fine and has plenty of power. Any ideas on what could be causing this problem ?
Why are you not setting the brake?????Yeah, I know!
This is happening when the parking brake is not set. It doesn't have to be on much of a grade to cause the car to roll. It is something that has just started within the past month.
Yes, the parking brake was left off.I think you're missing the point of the question. Is there any reason the engine would not hold the car on a slight grade ?
Old farmer's habit. I pretty much only use mine if I leave the car idling. Mine holds on a hill just fine. I would check the compression just for kicks.Why are you not setting the brake?????
why is everybody so anal retentive about using the parking brake?And a defective parking brake. Because it's either inoperative or the driver is.
why is everybody so anal retentive about using the parking brake? I have driven manual trannys for 31 years and have virtually never used the parking brake when parking and have never had a mishap.And a defective parking brake. Because it's either inoperative or the driver is.
Not if the shutoff solenoid is functioning properly. (If it's bypassed or stuck open, however...)jrip said:Let me try this on for size. Mechanical injection pump, no spark plugs required, is it possible for a diesel engine to start running if the engine were to turn over, as in higher gear and steep hill?
In MD, it is the law.why is everybody so anal retentive about using the parking brake? I have driven manual trannys for 31 years and have virtually never used the parking brake when parking and have never had a mishap.
