TDIWAY
i have a friend/customer who has an 03 alh, and the biggest issue is i cant get his car long enough to do some thorough diagnostics, his car has 425,00km on it, he started complaining of CEL light on, and glow plug light flashing and intermittent loss of power, he can pull it over shut off and restart and drive for awhile again, i hooked my VAG-com up and pulled some codes, i dont remeber the numbers write off its been a little bit, but there was a brake light switch code set, a throttle position code, and all 4 glow plugs, so for kicks i checked all for glow plugs, i believe 3 of the 4 were burnt out, i replaced all 4, i also fixed some chaffed wires close to the tps i believe, cleared codes, problem still exists, so i check and repair all brake lights, install a new brake light switch and cleared codes, while i had vehicle the brake light switch code and tps code stayed off, but glow plug 2 and 3 wiring codes were set, he needed his car that night drove it a few miles glow plug light flashes and he got into limp mode again, im sorry for the lengthy post just trying to get as much info as possible, and next time i get him in i will record all the codes stored, i have not had enough time yet to check into the maf and some other limp mode issues so i just thought i would see what some of you guys thought
thanks
thanks
