03 Jetta ALH - Engine no start problem
Jedda03SGP
Glenshaw PA
2003 Jetta
Need a little insight. Just finished a clutch R&R, car started right after, but a day later, it won't turn over. First thing this AM I turned key, nothing, turned off key and tried again, the starter turned and it fired fine.
Got gas, went to fire up and nothing.
All lights come on on cluster, but no click at the starter solenoid.
Can't figure out which fuse controls the starter/solenoid.
Could it be the clutch switch puked coincidentally with my clutch R&R?
Could it be the metal clipped connector at the starter itself?
Could it be the starter itself (read on a couple threads about the braided ground going bad)??
Any help appreciated.
TIA
JETaah
mi 48836
Did you clean and tighten the engine ground on the transmission mounting bolt?
JETaah
mi 48836
"272,000 and goin' strong"
Whaaaattt? ;)
not yet
Jedda03SGP
Glenshaw PA
2003 Jetta
JET, yes I had all connections cleaned up and greased with di-electric grease.
Turns out the problem was the single wire lead to the starter solenoid. It had work hardened and cracked right at the connector, under the bright green grommet that inserts into the end of the connector.
Cleaned it up and re-soldered the metal connector, which I was able to extract from the connector by inserting a 2mm allen key into each side release and yanking out.
Would post a picture of the connector if someone could clue me on how to attach photos.
Thanks,
Steve
rwolff
Lesser continental mass, Tosev 3
None yet
In your original post, you said you got GAS. If it had fired up, you could have damaged the VE pump. As it stands, all you need to do is drain the bad fuel out of the tank and fill it with DIESEL.
Jedda03SGP
Glenshaw PA
2003 Jetta
rw, sorry, missed the subtlety of your post, and my lack of attention to detail. Anyway, I did not put "gas" in it, :eek: fortunately, but I have had the car for 9 years now !!!
Thanks,
Steve
