TDI4MI
Any recommendations on trans work?
My golf has 238k and unknown on previous work. I had some issues shifting into gears. Pretty nudgy. I did a replacement of slider, shaft bushings and adjusting the shift cables...helped just a tad. Shift into gear fine when car is not running. Reverse doesn't grind when slowly engaging, so I am thinking the clutch is fine, since its not synchronized. So I am assuming at this point the syncro. Never rebuilt one, and dont have the time to do so. Otherwise would take a stab. Hoping for a recommendation in Michigan or nearby state.
Thanks!
Thanks!
