02J rebuild
TDI4MI
SW Michigan
00 GOLF ALH 1.9 TDI MKIV
Any recommendations on trans work?
My golf has 238k and unknown on previous work. I had some issues shifting into gears. Pretty nudgy. I did a replacement of slider, shaft bushings and adjusting the shift cables...helped just a tad. Shift into gear fine when car is not running. Reverse doesn't grind when slowly engaging, so I am thinking the clutch is fine, since its not synchronized. So I am assuming at this point the syncro. Never rebuilt one, and dont have the time to do so. Otherwise would take a stab. Hoping for a recommendation in Michigan or nearby state.
Thanks!
jayb79
Exeter,NH
I would try changing the oil before you do anything. You will be amazed, Penzoil or AC Delco Synchromesh Manual Transmission Fluid. Easy to do 3 quarts is all you need and it will shift like new.
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
I think Richard (CoolAirVW) is located in MI; he's an automatic transmission savant, but also deals with just about anything VW related.
(Edit: My bad - he's in Kansas City; I was sure there was someone in the vendor forum who's based in MI. Maybe take a look through there.)
That said, $30 and an hour or so of your time gets new fluid in to see if that helps. I used OEM VW fluid with my new (to me; 300K km) transmission and no complaints. It was cheaper than the Synchromesh that I could find locally, so that's what I went with.
Unless the transmission has been significantly abused, you shouldn't have trouble at that mileage. As recommended above, change the gear oil and see if it improves. I recommend Pennzoil Synchromesh. Solves all kinds of problems.
I
Nuje
Which Pennzoil Syncromesh is the "right" one? I had put some in the 02M in a previous car, and it was great; then couldn't find that same bottle again and got some different stuff....which was not.
