Scott_DeWitt
Here's an invaluable how to to modify the 02J case in improving lubrication to the 5th gear area.
This photo is the case as it is before modification.
In the area marked, take a 1/4 inch drill bit and drill holes, pushing to the side to make a large oval for the port in the middle. The final product should look like this:
The reason for 5th gear failure is when the oil level gets the least bit low, the 5th gear is starved for lubrication. This image shows the lowest oil port from the top fill hole in the transmission. As you can see even at stock oil levels, the stock fifth gear port is marginal.
We perform this same modification on all our 5 speeds. It's possible to do this modification with the transmission in the car, however due to the amount of shavings that are produced I wouldn't recommend it.
