mrbowtieguy
I just picked up a 02 Jetta with 289k, the cam lobe is worn mangled and the follower is collapsed on #3 cyl. intake valve. But its not because of a timing belt failure, previous owner stated the timing belt was replaced 50k ago. and visual inspection indicates no deterioration or cracks, The cam, IP and Crank all line up. Car runs but very bad miss which is expected with a valve not opening.
My question is what are other causes of a failure like this besides a timing belt.
next question is if you already have the head off and the pistons look ok i should probably put a fresh TB kit while its tore down that far. I'll have the head reworked.
