2002 Jetta Auto, 197k. I have owned this for 3 years and have had no transmission issues, no codes from it, etc. Recently my I discovered a small power steering leak and noticied that my TDIHeater had worn a pinhole in my pressurized power steering line. I replaced it last weekend, and on it's first test drive, it will now not shift into 4th. Had a club member scan with VCDS and received the following code:
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 KT
Component: AG4 Getriebe 01M 4891
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00281 - Vehicle Speed Sensor (G68)
03-00 - No Signal
00652 - Gear Monitoring
27-10 - Implausible Signal - Intermittent
So in searching here I gleaned that obviously it the G68 VSS, and the 03-00 indicates it is not getting a signal at all from it, which leads me to a wiring/connection issue. This leads me to believe that I must have done something when I was re-routing the replacement power steering line. Using CoolAirVW's pic:
I verified that all 3 above connections seem tight. Any insight into what the heck I did? I definitely moved the solenoid connector in the above pic when I put in the new line as the power steering line uses the same bolt to attach the bracket, but nothing looks out of order.
CoolAirVw, are you out there??
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
03-00 - No Signal
