MaverickH1
It seems like the best way to go about doing a swap to an 02j is to simply purchase a parts car and steal parts off of it. Is the only way to do this to find a manual transmission TDI? Or would a manual transmission gas MK4 Jetta work equally well while ALSO being significantly easier and cheaper to find? Does it have to be a specific year of MK4 Jetta?
Is there a better transmission to use? For example, on Humvees for example the 3 speed transmission from the 80s is identical to the 4 speed transmission of the 90s, and it's possible get the next generation transmission bolted up with other little changes such as crossmembers, driveshafts, etc. I didn't know if the next generation 6 speed manual from the newer TDIs would be a similar thing or not.
I landed a great condition 150k mile 2002 Jetta TDI for $1000 a little over a year ago. It didn't start, all it needed was one of the o-rings on the injector pump replaced. It has been saving me money on my 30 mile commute since and has already paid itself off from the savings.
The only down side is that it has the 01M transmission. It started to shift hard in the final gear shift from 3 to 4. It also will drop in RPM while in 3rd gear as if it slowly and smoothly shifted... and then it'll do the thing where it feels like it takes forever to shift into 4th and jolts when it finally does. The changing in RPMs while still within a gear is so extreme that when I was counting gear changes during trouble shooting I was certain it was a 5 speed transmission, which obviously it isn't. it exhibits behavior like that in other gears *sometimes*.
I decided to do a fluid/filter change. Everything looked decent inside, of course, the filter was probably original to the car based on the date on the filter. I'm just never going to trust the 01M transmission, basically. So instead of throwing $500 at a valve body, and other random fixes that have no guarantee of working, it feels like it'd be smarter to just buy a $1000 parts car and swap everything over and replace wear parts at the same time.
I'd like to get the transmission issues figured out before I sink more into the car and do the timing belt that is due in ~15,000 miles.
If the car is benched, I'll probably rip the engine out of it and make a street legal go cart or a boat out of it or do a conversion on another vehicle or something. I love these engines!
