01315 on manual swap, way to disable codes?
cuban11182
North Carolina
1984 CJ w/ ALH GTD1756, 260 injectors, and Tekmektronics tune
So I did a swap a few months back and just recently got a check engine light (unrelated glowplug #3, so ordered a new harness and 4 new plugs) and when I checked it I found the reason for the check engine light, but found two instances of the 01315 code as well. When I did the swap I used VCDS to change it from auto to manual. Is there anyway to disable these codes? It's a 2002 Jetta sedan TDI if it's important.
Thanks.
Tuesday,06,August,2019,17:34:18:56356
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: 3VWSP69M12M018680 License Plate:
Mileage: 271120km-168466mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSP69M12M018680 Mileage: 271120km-168466miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 2A0D001D30E2EB17B4D-5160
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A2D305DC5425B97C4D-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 00066
VCID: 30391275133E91C77A9-5216
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 M
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 00050
VCID: 323D187D1D32A3D70CD-513C
3VWSP69M12M018680 VWZ7Z0A3832656
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70B9D275D3BED1C73A9-513C
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 372B2969F65046FF3B3-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0002
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02041
Shop #: WSC 05080
VCID: 3E253C4DD96A77B7F85-51CE
End----------(Elapsed Time: 05:01, VBatt start/end: 11.9V/12.2V)-----------
Nero Morg
OR
Connect VCDS to the instrument, go to coding, change the 1 to a 2. Same. Done.
cuban11182
North Carolina
boertje
Coeur d'Alene, ID
'01, '01, '03, ‘06 NB - TDIs all.
I’ve had to do this provided your wiring is correct and TCU removed.
On MY 2001 and earlier, go to CAN-bus gateway>coding and change the 7 to a 6 to remove the automatic transmission feature.
Look at the last digit in the coding. Add the values for the options together to get the correct coding.
0 - No available equipment
 +1 - Automatic Transmission
 +2 - ABS Brakes
+4 - Airbags
So, if you want to support Automatic Transmission, ABS Brakes, and Airbags, (add 1+2+4 = 7) = 00007.
Note: 2002+ models do not need to be coded separately for automatic transmission, so a 2002 with Automatic Transmission, ABS Brakes, and Airbags, (add 2+4 = 6) = 00006. In my Golf, the coding was 7 so I changed it to 6 which subtracted the automatic.
Not necessary on MY 2002 and later. However, It has been discovered that some 2002 and later cars are having TCU communications error codes even though the wiring and coding was done correctly. If the 19-CAN Gateway is checked with these cars, the value is 6 as it should be. What is interesting (thanks to “the*rogue” for this one) is that if the value is changed to a 6, which it already is, and saved, it forces the ECU to rescan the devices and finding no TCU, it is now happy and the codes do not reappear.
Make sure you cycle the key after each change and then check for fault codes.
cuban11182
North Carolina
That fixed it!
Thank you!!
