Texas_sky
Here is the problem... If the motor is running with a gear engaged and the clutch pedal is fully depressed the car continues to pull forward. You can remove the selected gear but not reengage it; however, if the motor is shut-off then you can freely engage all gears.
Clutch is new. The mechanic who swapped the engine recently said
Both clutch master and slave cylinders are new and operate fine. He wants to remove the transmission and inspect the clutch and release arm.
Anyone that has had this same issue or any ideas what it could be holding it from going into gear? The car was previously a automatic and was swapped to a manual. Thanks in advance! Should be a nice car to drive once I get this problem squared away with.
