JDSwan87
Black Swamp Thing
- Joined
- Feb 9, 2014
- Location
- Michigan near Toledo
- TDI
- 2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
99.5 Jetta flashing glow plug light.
VCDS scan yielded a 00741 fault, Brake Pedal Monitoring Implausible Signal.
Foot off brake, VCDS measuring group 006, block 2 shows 001 (I know it should be 000). Pedal pressed shows 011. I disconnected the switch and VCDS shows a 011.
Car harness Pin 2 & 3 show 11.57V
Pin 2 & 3 on switch show continuity. No other combination on the switch shows continuity regardless if plunger is depressed or not.
Is my switch bad?
Current switch part number 1C0945511A
Is my switch bad?
