Fox_Kid_263
Ok, check engine light is on scan get 00293 code, the gear slector screen is outlining the digits in black on the dash, the trans would not work properly, it would shift funny and slip a bit.
I checked the connectio - good, so I replaced the Trans Multi-function Switch, cleared codes and all is good, shifts fine and doesn't slip.
A week or so later the engine light comes back on and the gear slector screen outlines in black, re-scan same code. Check connection - good. Clear codes everything goes back to normal and works?
Now not sure what to do?
This is on a 2001 Golf TDI with an Auto
