iarp
Long ass story short, we drove the car home from the local shop with a leaking slave cylinder and a quote for approx $500 to fix it.
After a bit of searching, i removed the air box and found the device and it's leaking line.
The metal line that comes from the master clutch cylinder has a one-piece nozzle on it that fits into the slave cylinder quite tightly. The issue is that the line and the nozzle are very loose. So loose in fact that brake fluid is leaking from between the nozzle and the line(not the nozzle and cylinder). Right in the head itself, somewhere i cannot get to to fix myself. That leads me to believe the cylinder is actually OK, but it's the line connection failing.
We followed the line and found it ended at the master, we are prepared to yank the whole line out and replace it. Anyone have any idea what those lines cost? And/or do i really have to replace the entire line from master to cylinder. I tried to use a mirror to my best but it was dark and hard to see properly, it looks like a solid metal line and a crimped rubber hose at the slave end.
