Jhk
Dose anyone know why my ‘Oil change needed! Service Vehicle’ light keeps popping up even though service has been completed on my 2015 Passat TDI?
Hmmm, did this and although it resets the service miles, I’m still getting the ‘needs oul change’ light.For a 2015. With car off, hold down the trip reset button in the cluster, turn the ignition on (foot of the pedal for kessy systems) MFD will prompt if you want to reset oil service.
repeat but turn hazards on before starting, and that will do the inspection service.
This is a holdover of the mk7/MQB ECU stuff that the 2012 and 2014 Passats don't have, even though the cluster looks exactly the same.
Thank you for this!! Works on 2014 also. I had previously figured out how to turn off the oil change reminder, but couldn't get the "inspect now" chime to turn off. This just worked.repeat but turn hazards on before starting, and that will do the inspection service.
Did you get the oil reminder to cut off I'm having the same problemDose anyone know why my ‘Oil change needed! Service Vehicle’ light keeps popping up even though service has been completed on my 2015 Passat TDI?
Thanks for the replyJust had mine changed bye the dealership 3000 miles ago they didn’t reset the thing. Wife drivers the car she just told me about it. Spent over a hour trying to rest told her to call the dealer in the morning.
Getting the same issue with my 2015 Jetta TDi. How to reset?Hmmm, did this and although it resets the service miles, I’m still getting the ‘needs oil change’ light.
Never could get it to reset . It’s about time for another oil change and going to make sure dealerships reset this time.Getting the same issue with my 2015 Jetta TDi. How to reset?
We reset with the scan tool and a day later it came back on. Trying to get this mystery figured out. FWIW, my TDi has the Stage 2 Malone tune. Not sure if that is an issue.Never could get it to reset . It’s about time for another oil change and going to make sure dealerships reset this time.
I have the same problem and have also wondered if the tune was affecting it.We reset with the scan tool and a day later it came back on. Trying to get this mystery figured out. FWIW, my TDi has the Stage 2 Malone tune. Not sure if that is an issue.
Reset the tune to stock and did the oil change and inspection resets. No joy. Put the tune back since the Dieselgate tune is pretty wimpy.I have the same problem and have also wondered if the tune was affecting it.
