Sword_of_the_Spirit
Hello All,
I’m having an odd issue with my Wife’s ‘05 BEW Golf. If the temp is below 37 degrees (e.g. ambient and block temp from overnight), it will “glow,” but not start (will turnover) until fuel is added via accelerator. Multiple ”glow” cycles are initiated with no change. When adding fuel, it starts up immediately without hesitation or abnormal vibes such as “dieseling.” When it is above that temp, there are no issues. Same when the engine is warm.
Some recent work from myself was replacing the lift pump that recently went out. As a side, there were no issues prior ”winter.” Things I know: Fuel is not gelling, 1.9’s can start without glowing reliably down to 25 degrees, no water in fuel, filter replaced 4kmi ago…. Verified all connection and all seem well. Airbox is clean/a-ok with filter replaced 4kmi ago.
Something leads me to believe coolant sensor….. But that’s just a guess. I do not believe this to be related to the MAF as that could pretty much fall flat on itself and the 1.9 would still turn over…..
Searched forums with not a similar issue oddly.
Thought someone might know before I check to see if there are any stored codes. Yes, this is a semi-daily driver.
Thanks all…..
Thanks all…..
