Actually it's not the first report from Bosch. The first one contained terrifying pictures of the inside of an injection pump after running a lot of bio. Of course, they also say that they were using bio with an extremely high glycerine content. This study is more of the same, it is not bio that is the problem, but quality bio. Quality, Quality, Quality. That is the issue. They even refer to running a test fleet with sub standard fuel to see what will happen! I think we know what will happen and the poor effects will be (and show up as being) proportional to the quality of the fuel used in the study
Why is it that companies don't run tests with substandard diesel or gasoline, and from the bad results claim that diesel and gasoline are bad? But of course, such a test and conclusion is perfectly fine with biodiesel....
There are some serious flaws in that report - they can't even get some of the basic science right. For example, on slide 2, they claim that as the percent of double bonds increases (the oil is less saturated), cold flow properties are negatively effected. No, it's actually the complete opposite. See
this thread over at biodieselnow. Methyl linolenate, for example, has three double bonds (18:3), and a freezing point of -70.6 F. The fully saturated C18 biodiesel molecule, methyl stearate (18:0), has no double bonds, and a freezing point of 102.4F. Yet, Bosch is claiming that biodiesel with more double bonds has worse cold flow properties? Uh-huh....
On the same page, they claim that increasing double bonds decreases oxidation stability. No, actually it has nothing to do with oxidation stability. The stability against polymerization or peroxidation increases, but oxidation must happen first - and is not affected by the number of double bonds. In study after study, well made biodiesel that retained the natural vitamin E was MORE stable than most diesel fuel.
On the previous page, they claim that the existing ASTM spec is insufficient to protect the consumer, since it does not include an oxidation stability test. Neither does ASTM D 975, the diesel spec - why aren't they complaining about that?
When they have that many mistakes on the basic science in just the first two pages, one has to ask - what is their agenda?
All of the "characteristics" they describe on slide 3 are traits of bad quality biodiesel - well beyond the ASTM spec. Of course, that doesn't stop them from claiming these are reasons to be wary of ALL biodiesel.
One also has to wonder - why is it that all of the tests done by independent groups (university research programs, government agencies, fleets themselves, etc.) find none of the problems that "studies" done by Bosch and VW report?
For example, Bosch's presentation is claiming that in studies where they used B20 for only
4 weeks, the result was a sludge coating most components, o-ring swelling, and zinc coating deterioration. Yet, studies where even B100 was used for years (in many cases 10+ years) showed NONE of those problems. Consider for example Yellowstone national Park's use of B100 year-round (with a fuel tank heater) in a 1995 Dodge pickup truck since new, with now over 200,000 miles on it, and no problems (the periodic inspections showed far less than normal wear).
Does it not seem a bit odd that the company(ies) that make the vehicles, and would have something to gain by being able to claim biodiesel is bad and will void your warranty, are finding far moreproblems with far less use (i.e. 4 weeks versus many years at much higher blends) than independent studies?
There is nothing in this report that damns biodiesel. Further, if people are willing to take the time, you will find several psotings by me on the test results of my own fuel. There you will find that my fuel beat all of the stndards inlcuding corrosion. I have fuel samples in my garage that are over 3 years old and are still good to go (crystal clear). Quality, Quality, Quality.
No no no, if ANY biodiesel can be claimed to be damaging in a test done by Bosch, ALL biodiesel must be bad. Right?
