Gigitt
Ok... I ust got my Vag-Com and got an Engine error
00539 - Fuel Temperature Sensor (G81)
30-00 - Open or short to B+
I have read all the posts about the FTS but mine is different!
My Vag-Com mesurments show that the FTS is locked at -5.6degC.
So basically my car is running lean due to the fuel density mapping the ECU is doing when pumping fuel - cold fuel is denser so the ECU will inject less fuel to get the same result if fuel is a different temp.
So Is it bad to keep running like this?
Mind you - the last time my car was Vag-Com'd was when I had the Timing Belt replaced and that was 2 years ago. So I could have been rinning lilke this since then!
Car is not affected. No stuttering, no lumpy idle.... it runs perfectly like the day I got it 6 years ago (too a degree)
Replacing the FTS would mean that my car would run better!
As every one else who FTS died reported the FTS was locked in at high temps like 100degC - which meant that the ECU was pumping more fuel than should be and more smoke produced in theory.
I know I have to replace it to get the TDi timing to work etc as these require FTS to be withing operating range - which it is not at the moment.
